OEM trailer brake controller 2018 Big Horn
Scarfie
NC
Benny -
I want to buy the correct OEM trailer brake contol module & bracket for my 2018 Ram 1500. I already have the slider control. Truck VIN is 1C6RR7LT5JS237964.
kindly provide the part number and any coupon codes so I can order. Much thanks!
All
All
Hi,
Here are links to them
Youll need x3 screws according to our data. I will send you a code now
- Benny
cbird02
Tucson, AZ
2020 Ram 1500 Classic
Hi,
- Benny
Benny, I would like a code for this also .Thanks
cbird02
Tucson, AZ
Hi,
- Benny
I understand that you also need to security gateway module bypass and and ODB programmer for 2018+? If so, any suggestions for those and instructions for the programmer?
How about the switch?
I have a 2020 Ram 1500 Classic 5.7
Administrator
I don't think Mopar sells a security bypass cable but you can get one from another of the forum vendors:
As for programming the trailer brake controller, you can take it to a dealership (won't need the bypass cable) and have them program it or use AlfaOBD to program it. How to use AlfaOBD: https://www.ramforum.com/threads/alfaobd.123982/
