- May 27, 2023
- 1,730
- 1,912
- Location
- Sthrn AZ
- 2023
- 6.4 Hemi
Mine has two different methods. You can take the long way around:Turn the ignition to "Run" but don't start the engine,and then step on the gas pedal 3 times in fairly short order,turn ignition off,open and close door,and that should reset the oil minder.
Oil Life Reset Procedure
1. Without pushing the brake pedal, push the ENGINE
START/STOP button and place the ignition to the
ON/RUN position (do not start the engine).
2. Push and release the down arrow button to
scroll downward through the main menu to “Vehicle
Info.”
3. Push and release the right arrow button to
access the ”Vehicle Info” screen, then scroll up or
down to select “Oil Life.”
4. Push and hold the right arrow button to select
“Reset”.
5. Push and release the down arrow button to
select “Yes,” then push and release the right
arrow button to reset the Oil Life to 100%.
6. Push and release the up arrow button to exit the
instrument cluster display screen.
Or you can do it in 10 seconds:
Secondary Method Of Resetting Engine Oil Life
1. Without pressing the brake pedal, push the ENGINE
2. Fully press the accelerator pedal, slowly, three times
within ten seconds.
3. Without pushing the brake pedal, push the ENGINE
START/STOP button once to return the ignition to the
OFF position.
