P219A
REVSRAM
ohio
I have the dreaded p0219a code on my 2013 RAM 5.7 plus no other codes set and I've been chasing it for a while now. its driving me crazy lol any ideas or suggestions
I just haven't found the best way to check fuel pressure
aszumilo
Las Vegas
Some possible causes of that code:
  • Engine vacuum leak
  • Defective oxygen sensor
  • Engine exhaust leaks
  • Faulty mass air flow or manifold air pressure sensor
  • Faulty Exhaust Gas Recirculation (EGR) system
  • Positive Crankcase Ventilation (PCV) system leaks
  • Bad fuel pump
  • Leaking fuel injectors
  • Low fuel pressure
  • Clogged fuel filter
  • Issues with the electrical wiring and connectors
I'd start with the easy things to check, like vacuum leaks and work my way up from there.
R
REVSRAM
ohio
K had a lifter failure ,I replaced the cam and installed hellcat lifters and rods, now I still have the p219a code and I know it's from cylinder 5 and the leak down test has air coming out the intake manifold. so I swap out my heads with ones that have been machined and already has new springs installed and still same issues,
So I was wondering has anyone ran into the issue where the rocker arm might be bent and causing a valve not to seat correctly
aszumilo
Las Vegas
Did you use the same rockers on both heads? If so, then could be possible. If you have another set of rockers, try swapping the bad one out and see if it makes a difference.
