autumnwalker
My MY2015 1500 has a sagging parking brake cable and a warning light that will randomly come on (even with brake physically disengaged).
Story below, but TL;DR - is there any sort of improved solution we can put on the trucks to avoid this in future? I'm not really down for replacing my parking brakes every couple of years - especially when you are "supposed" to remove the axles to do it!
Full story:
So, I brought the truck to the dealer to look at why my warning light randomly comes on. Their diagnosis is that the entire parking brake assemblies need to be replaced as they are completely worn out.
I'm not sure how a truck that has been in service for less than three years and has under 43,000 kilometers on it wears out a parking brake, but as far as FCA is concerned this is all my fault and no warranty as it is a wear item.
I took it to my independent mechanic and he is certain that the issue is simply that the parking brakes need to be adjusted, that they are not worn out (they hold the truck fine), and the reason the warning light comes on is because there is so much slack in the cable and the pedal goes so close to the floor to engage, when you pull the release it flies up with so much force it bounces and partially re-engages a couple of "clicks" down - just above the point of engaging the warning light. If you release the pedal, then pull the release and pull up on the pedal it will travel upward close to another inch, thereby not tripping the sensor.
Is there some sort of upgraded, improved solution so that these things actually adjust themselves, don't stick, don't get slack, etc.? The issue is everywhere on this board and elsewhere when searching online. I cannot believe that 1) FCA has not recognized the issue and 2) there has not been any improvement in the system over the years.
Full story:
