Skeeter94
Looking for the best bang for the buck on a performance package I've looked at a few including the ones from Moe's Performance. But I'm looking for a good start up package for a stock 5.7 Hemi. All opinions welcome
Lastly this isn’t a performance upgrade per say but worth every penny. Buy an oil catch can, just do it you’ll thank me later. I run a BT catch can but there are a few other great brands out there. Nick@Gotexhaust has a good selection
It has an 8 Speed with 3.73 gearing I believeYour Ram is a '14 which transmission do you have? What rear end gears do you have?
Yeah, but with Pedal Commander on Sport+ #2, Superchips 93 octane tune and traction control off it breaks both tires loose on a hard launch. Weird.Same here...better than the 3.21, but that's about it...
Long tubes headers, catback, intake, tune, and a catch can are a great start. most of these mods will not only add power but support future mods like cams, forced induction, etc...Long tubes with a tune are going to be the biggest bump in power you can easily bolt on. Catch can is great for many reasons. it is more of a preventative maintenance. I have a can on 2 of my personal vehicles.
Message me if you would like more info and pricing. We can put together a great package at a killer price for you.
I keep seeing this catch can being mentioned, what does it prevent or its purpose?
https://www.ramforum.com/threads/upr-catch-can-install.159754/#post-2267286I keep seeing this catch can being mentioned, what does it prevent or its purpose?
https://gotexhaust.com/i-23720374-upr-09-20-dodge-ram-5-7l-billet-oil-catch-can-z-mount.html
essentially it keeps the oil vapors from getting recirculated thru your PCV back into your intake which can lead to build up on your valves and possibly lower octane rating.
I haven't done the numbers on a Ram but I did them for my wife's 2002 Mustang V6 just for giggles and here's the kind of difference gears make to torque at the wheels in any given gear:
V6 Stock 225 ft-lbs w/ 3.27
1st 2.84 2089
2nd 1.55 1140
3rd 1.0 735
4th 0.7 515
Speed At 5000 RPM 169mph
RPM at 75MPH 2225
V6 Stock 225 ft-lbs w/ 3.73
1st 2.84 2381
2nd 1.55 1299
3rd 1.0 837
4th 0.7 587
Speed At 5000 RPM 148mph
RPM at 75MPH 2525
V6 Stock 225 ft-lbs w/ 4.10
1st 2.84 2619
2nd 1.55 1429
3rd 1.0 922
4th 0.7 646
Speed At 5000 RPM 135mph
RPM at 75MPH 2800
V8 Stock 302 ft-lbs w/ 3.27
1st 2.84 2804
2nd 1.55 1530
3rd 1.0 987
4th 0.7 691
RPM at 75MPH 2225
In other words a stock V6 Mustang with only 4.10 diff gears should be able to give an also stock (heavier) V8 Mustang a run for its money at least up to highway speeds when they'll be on a level playing field vs. aerodynamics.
I don't know how that would compare exactly with our trucks but since 3.21 to 3.92 is a 22% increase that means whatever you can do now you'd have 22% more of it before touching the engine. You'd be giving up a little hypothetical top speed but we don't have enough horsepower to go that fast in a brick anyway.
If you had 3.55:1 gears and went to 3.92 that's about a 10.4% increase... not nearly as significant. I'd still do it if it was free or if I wanted speed and cost wasn't a factor.
