Possible non-resistor LED fix for Rear lights...
rixter99
SW Arkansas
2014 3500 SRW
Cummins i6.7
Found this video that talks about connecting a green/white wire to ground to fix hyper-flashing after replacing rear light bulbs with LEDs...It mentions it's for 2015 Cab Chassis and instructions on what to do with 2014 models (around the 58 seconds mark)...
On my 2014 3500 SLT LWB SRW, I located the blunt cut green/white wire under the TIPM and followed the instructions...I disconnected the existing resistors, connected the green/white to body ground near the TIPM... I no longer receive the left/right turn signal out error message on the EVIC (also didn't receive error with resistors previously connected)...I used AlfaOBD to change to LEDs...
My rear blinkers still do not light up (flashers, brake, parking lights DO work) - which is what I was trying to resolve originally (no voltage at connectors on either side), when I ran across the video...
davidhiller666
Cedarburg, WI
I have Sylvania leds in my '14 1500 tails. Never installed resistors and just used Alpha to switch the setting to LED tails. Never had a problem with them.
Diller
'14 Outdoorsman
Sent from my SM-G988U1 using Tapatalk
Brian2081
Weatland Michigan
Hello Rixter, just a hunch but check the wire harness where it runs around the front of the left front cab mount. You will need to pull the left front wheel well liner to get easier access. I found a chaffed through wire at this spot for my trailer lights.
rixter99
rixter99
SW Arkansas
2014 3500 SRW
Cummins i6.7
Thx Brian...It is affecting both L/R turn signals...I'm trying to eliminate everything else before pulling that fender liner, but I'm probably at that point...
UnkoBro
Honolulu, Hawaii
Do you have the link for this video? I don't see it on this post. Thank you in advance!
rixter99
rixter99
SW Arkansas
2014 3500 SRW
Cummins i6.7
Sorry Dude - just saw this...Here's the link...Can't believe I didn't include the link originally...
RedSRT4Me
Scottsdale, Az
2015 CC Sport
