PROGRESS LT Sway bar systems at Got Exhaust
Nick@GotExhaust
Preferred Vendor
SC
FITS: 09-22 1500 Classic 2WD | 09-22 1500 Classic 4WD | 19-22 1500 2WD | 19-22 1500 4WD
PROGRESS LT Sway bar systems are an ideal suspension upgrade for your light truck or SUV. Bolt on Progress LT Sway bars for significantly better handling on the highway and your daily commute. The added level of control also is also beneficial while towing or hauling a heavy load. A better handling vehicle also means less driver workload and a more comfortable driver behind the wheel.
Features and Benefits
  • Reduced body roll for enhanced cornering
  • Less sway and more precise handling
  • Improved tracking during crosswinds
  • Improve vehicle control while towing
  • Straightforward bolt-on installation
  • Limited lifetime warranty
  • Made in the USA
Products Notes
  • Rear Sway Bar, Ram
  • Diameter: 1.00" (25mm)
  • Adjustable design
  • Includes polyurethane bushings & lube
  • Optional end link available
  • Fits OEM height vehicles within +/- 2.0"
  • Powder-coated Metallic Gray
Message me if you would like more information or a quote.
Nick@GotExhaust
Nick@GotExhaust
Preferred Vendor
SC
Get rid of that wimpy stock sway bar and add better handling with a Progress Sway bar!
