Overlander
- Sep 12, 2020
- 370
- 534
- Location
- Oregon
- 2021 75th Aniv Build #0006
- 6.4 Hemi
I'm a data guy IRL (application developer/DBA). There have been a number of posts regarding axle locker issues so I figured I'd do a little charting to give some perspective of the issue.
I'll update the second post with the data as it accrues. For now, please post up your status - whether you have a problem or not! We want both the good and the bad for this to be a representative sample. Though, it will never be statistically accurate as this user base is canted; we have both enthusiasts and those coming here specifically looking for a solution to a problem. So this data will likely read high compared to the actual rate in the wild.
These are the minimum fields I'd like to collect. I'm completely open to add others. And the analytic fields will definitely be expanded as the dataset grows. This just a sample and will be revised.
