Rack and pinion preload/mesh adjustment?
hal9000
Flagstaff AZ
The rack and pinion in my '12 1500 is getting a little loose (no surprise with the mileage). I can see what looks like a mesh adjustment on the front side of it but haven't been able to find any specs or adjustment instructions online.
Does anyone have adjustment info on the R&P?
Thanks all!
Jeepwalker
WI
2012 Reg Cab, 4x4
I don't know the exact amt of preload. This video might give you some idea. There might be other videos.
H
hal9000
Flagstaff AZ
Saw that. Was looking for ram specific knowledge. I've heard our rack is non adjustable. I'm wondering if maybe preload is set by shims or something else that would limit stop adjustment....
Cash22
Don’t know anything about that, my problem is finding an electric rack/pinoin for 2013 ram 1500 crew cab rwd 5.7. All the sudden power steering guitar. No leakage no warning, nothing even lit up on dash. Any input?
hunterdan
SE PA
2019 classic
P
Check the intermediate shaft. Try spraying some lube on the joints and see if it loosens up. If it does, if get one of those on order.
Jeepwalker
WI
2012 Reg Cab, 4x4
Are you sure it's the rack? ....and not the 5 joints in the intermediate shaft that often wear?
Chumbucket12
did you ever end up doing the adjustment? I'm trying to do it right now but don't have a nut, bolt, or tool big enough to do it.
mkin
b.c. canada
Anyone ever figure this out? I have a 2017 ram 1500. Just got this changed due to some one hitting the left tire hard enough to damage the entire assembly. Been asking around and people are saying it's all electric now and can possibly be adjusted through there. But the preload / mesh is mechanical, no? If this is done through computer I have the means to do it just don't know what adjustments to make. Or if someone know how to do this pls inform.
