radio volume increases at random
Mike Cates
Ontario canada
Hemi 5.8
morning, first time post here.
i have a 2019 WARLOCK with a 5.7 Hemi. When i have the key on accessory, listening to the radio, the volume will spike every now and again. this started last summer, took it to dodge and they said it didnt happen to them but they updated the radio anyways. seemed to go away(or at least i never noticed it although i wasnt driving as much due to covid)
recently it happened again, only this time the display on the instrument cluster where the digital speedometer is went from reading 0 to - - - while the volume spiked. again with the key in accessory.
has anyone ever had this happen before?? i called dodge and all they did was check to see if there was an update for the radio again....
dhay13
My uconnect updated last night then today i was pulling into a drive through and it went up quite a bit louder randomly. not sure if it was related to that update or what but it was the first time it happened in 2 years i have owned it. i do have mine set to increase with speed but i was actually slowing down and only going about 3 MPH when this happened today
OC455
Central NY
Check in your menu to see if the radio has the volume set to adjust with the speed and stuff. Maybe shut it off and see if that helps.
Daw14
i have a 2019 WARLOCK with a 5.3 Hemi. When i have the key on accessory, listening to the radio, the volume will spike every now and again. this started last summer, took it to dodge and they said it didnt happen to them but they updated the radio anyways. seemed to go away(or at least i never noticed it although i wasnt driving as much due to covid)
You have a 5.7 liter,345 cubic inch hemi
M
Mike Cates
Ontario canada
Hemi 5.8
I will try it today.....not sure why it would make a difference as i wasnt driving, but i will try anything lol. thanks
co-pilot
houston,tx
my first radio did it all the time ........now on my second radio and it does it too but not very often.....or should i just say that i don't notice mutch because I almost never have it on acc.
RodeoRam
North Carolina
Hemi 5.7 2500 CC
What radio do you have, Mike? And when you say your volume spiked, did it go max volume or just somewhere in-between? My 8.4C UAS has become self-aware twice in the last couple of months going max volume, and the only volume change I could make was muting it. No knob turning or button pressing to lower the volume did anything except the mute button. Then after sitting all night, it was fine the next morning.
M
Mike Cates
Ontario canada
Hemi 5.8
I have the same 8.4C radio. it didnt go to max but it was alot louder. the volume spike never lasted long enough to try any volume changes as it would only last for a sec or 2.
M
Mike Cates
Ontario canada
Hemi 5.8
turned off the speed adjust and it didnt do it all weekend. Guess i will be keeping that off. thanks
No Tyme
Bryan, Ohio
My radio does the very same thing. I just opened another case with UConnect today as they closed the case Ram Cares started for me last fall. It is like clockwork every 5 minutes the radio will increase in volume AND on my truck (the dash is set to show MPH) the 0 for MPH goes away and 3 dots appear for the 4 or 5 seconds that the radio blast. Only does this in ACC and every 5 minutes.
Also if you select the lower setting of the AVC it changes the amount the volume increases. Glad I have a warranty because I am afraid it may blow a speaker.
No Tyme
Bryan, Ohio
I just spoke with UConnect (again) and I have to return the truck to the dealership and have a "star case opened", where service techs with work with UConnect engineers to try and find the problem. I have an appointment set for the week of June 7Th and it is my understanding that they will have my truck for possibly a few days.
I will post any finding that they suggest.
Unfortunately bad timing as I am in the middle of moving and need the truck.
Work vehicle
Hudson, WI
V6
My 2018 Ram Big Horn (married man's edition - V6 no balls) does the volume modulation all the time and now has started to switch to right side speakers when it wants. It also cranks the volume when I am just sitting in it listening to the radio. Does this about every 5 minutes.
RamCares
n/a
n/a
Hello everyone,
We're sorry to hear about the various concerns you're experiencing with your Uconnect system and the varying sound levels. If you'd like additional support while working with your dealer to get this addressed, or you have concerns pertaining to these symptoms, please send our team a private message!
Thanks,
Courtney
Ram Cares
Ironhead3
New Brunswick Canada
2019 Ram 1500 Classic
The volume spike with mine happened when I was driving, and my volume button did turn it down, but not until I turned it far enough to mute the music, and when I turned it up to check it the first click clockwise and it was wide open again. I guess from what I am reading it will be a trip to the dealer .
No Tyme
Bryan, Ohio
I have chose to pass on giving my truck to the dealership for a couple of days so they could open a "star" case. I live over 20 miles from the dealership, no loner is to be given and I just don't see the point since its not a critical issue. Since I added some LED's and increased tire size I don't need them to flash the BMC looking for a bug that will cause me a few hours to reset everything I have done.
If someone does get a fix I hope you post what the fix consist of for us with this issue.
dbr7
NY
Pentastar V6
Does anyone have an update on this issue?
I have a 2021 RAM WARLOCK, V6 with the smaller 7" media unit.
It's frustrating. Every 5 minutes exactly the volume increases roughly five increments which is quite significant. It is a capable of turning it down when it occurs but I'm often not near the media unit so I suddenly get a blast of sound. No other symptoms during this time frame.
Its impatience and/or incompetence if dealers are having a hard time replicate this. They just need to be patient ( 5 min). Run ANY media while sitting in the vehicle. Do not get in or out of the vehicle or make any manipulations to the vehicles options and functions and it will occur.
I often listen to my radio for long periods on accessory and this is a very frustrating issue.
I have a year left on my initial warranty and I want this resolved before I sign my buyout.
I would like to go in with information if possible.
tron67j
Maryland
I had a similar problem with a different vehicle, turned out to be the adaptive sound that increases and decreases the volume as noise in the cabin moves up and down. The only way I could solve that was to turn off the adaptive sound. I don't know what options your radio have, but if that's a setting you might want to try that. See if that at least stops the volume from adjusting.
Mpgrimm2
Preferred Vendor
SC
2022 Ram 1500 (5th Gen)
5.7L
If you have audio controls on the back of the steering wheel, it could be the switches, or a pinched harness inside the wheel finally rubbing though.... They had a recall for that on the earlier 16-18 4th gens I believe.
