Ram 2500 acting like transmission issue or bad gas after muffler swap
Kdawg1962
New Hampshire
Hemi 6.4L
2022 Ram 2500 Big Horn, just swapped out a straight through muffler for a quieter one (similar to a stock muffler) Now truck acts like it is stuttering when I step on it a little at certain speeds, similar to bad gas. All the shop did was cut out old muffler and put in new one. No engine lights on dash.
jws123
nj
Are you sure your not hearing it drone due to the new muffler? what type of muffler did they use? does it have factory resonators? I would also scan it for codes or just take it back to whoever did the work.
K
Kdawg1962
New Hampshire
Hemi 6.4L
There is really no drone, the muffler before had too much cabin drone. Not sure about resonators. Yes I am going to have dealer look at it since I have a couple recalls. Just don’t understand the hesitations
SitKneelBend
Moderator
Member Relations Specialist
St. Louis
3.6 Pentastar
Was this truck used when you came to it? Possible it was tuned for the old setup?
K
Kdawg1962
New Hampshire
Hemi 6.4L
No this is more of a hesitation with transmission a jumpy feeling. Like something is preventing it from going? It’s not a smooth transition from gears. Again no engine lights. This was muffler shops version of a stock muffler transition from straight through. They said sound might be a hair above a factory muffler. Which has been true. Except at certain points when I step on the gas it gets jumpy like something is preventing it to switch gears smoothly, however once it gets up to a good speed I.e. 75 mph no issues, it’s when I might slow down a bit and then step on it to get back to original speed
04fxdwgi
Coastal NE North Carolina
2016 1500 Sport
Could it possibly be transitioning in and out of MDS mode? Don't judge it by the ECO light because that basically means nothing.
Change it to select gear manual mode via the steering wheel buttons and see if it stops.
I know mine makes a stumbling noise when transitioning that I did not hear / experience when the stock muffler was on there. New muffler "enhanced" the noise.
SitKneelBend
Moderator
St. Louis
3.6 Pentastar
The change might be enough that it's time to initiate a transmission quick relearn and/or reset the adaptive values. Do you have AlfaOBD?
EdGs
FL
A couple months ago, I did a muffler delete (kept the resonator) on my '15 SLT 5.7 single exhaust.
At slower speeds (approx. 20 - 35 mph), when I go to accelerate just a little, I can hear and feel the weird rumble from being in 4 cylinder mode.
When it does this, if I use the gear - button, it instantly smoothes out.
If I'm cruising at highway speed, it is not or barely noticeable.
I never heard the weird rumble before the muffler delete, just felt the slight hesitation when applying the gas.
Burla
2010 Hemi Reg Cab 4x4
You don't have enough back pressure, just Google it there are a few fixes.
So most of your issues are at low rpm?
Burla
Try driving with tow haul button, does that help even a little?
It’s got a Hemi in it
Back pressure is not a necessity.
What OP does need is proper exhaust velocity. Unless he’s got Honda fart cans going, that’s not likely an issue.
Burla
You don't need back pressure unless... you have to much flow, which is most likely his issue. Bad choice of wording, this I admit. You add baffling which is increasing back pressure and restriction. His third post suggests what he has is a low rpm issue after an exhaust install, in his own words cruising at higher rpm like 75mph it is totally fine. he needs baffling of some type would be my move.
K
Kdawg1962
New Hampshire
Hemi 6.4L
Well i took it to the dealer where truck was ordered from. There are no check engine lights. However dealer says they can recreate problem every time. They say it needs new transmission. Fighting with Chrysler over warranty coverage due to no error code to give Chrysler.
SitKneelBend
Moderator
St. Louis
3.6 Pentastar
Did they open a star case? It's a bit ridiculous when they get stuck on their process but it can be worked through (as their aren't sensors onboard tripping, they'll need to depend on the Mark 1 Eyeball and Earhole sensor package at the dealership)
K
Kdawg1962
New Hampshire
Hemi 6.4L
They just reached out and said new transmission is covered by Chrysler, but since it’s over 3 years I have to cover cooling box and transmission line?
