Rear License Plate Lights not working
dgardener
Alberta, Canada
Greetings all,
I've got a 2019 Ram1500 DT with factory LED plate lights that are no longer working.
I've checked all fuses and they seem fine. (underhood and in cab)
I've checked the connectors under the bed and they look fine (no green crusties)
I've checked the trailer sockets and have power at both the 4 and 7 pin connectors
wondering where to go from here any help appreciated.
Thanks,
Dave
crazy jerry
WY
fuses are either fine or they arent. theres no maybe. check continuity if you cant visualy be 100%
D
dgardener
Alberta, Canada
Apologies for the delay, I've been out of town
Ground has been verified, no power on the wires
Lights have been removed and both light up when power is supplied.
At this point I'm thinking there's a break in the wire supplying power to the lights but I can't find wiring diagrams / connector locations.
Can anyone tell me which connector and wire color(s) I should be looking at?
I'm also thinking it may just be easier to run a new wire from tipm to the lights but again need to know which connector and wire color on the tipm
Thanks again for all the help
KAKA
