Remove steering column cover
siepierski
Yuma az
6 cyl
I need to replace the multifunction switch on a 2019 dodge ram bighorn.
There does appear to be any fastener holes for removing the plastic shroud that houses the turn signal switch. Any ideas on how to remove the shroud?
Thanks
MidnightRambler
North Carolina
HEMI 5.7
Hey, assuming you figured this out, did you manage to change just the switch? As in did you keep your clockspring and transfer to a new switch, or did you buy a whole new $350+ assembly with the clock spring attached to the multifunction?
HarryS
Clovis NM
He only made one post, a year and a half ago. I doubt he will read your question.
