Motorman001
- Nov 1, 2019
- 11
- 12
- Location
- Kansas City, MO
- 2015
- Cummins 6.7
My truck is a 2015 RAM 3500 DRW Cummins with dual 220A alternators. My question concerns what is commonly referred to as the 12V power or auxiliary charging connection on the 7-way RV receptacle. This terminal is always hot, even when my truck is parked and turned off. I suspect that is normal, and I confirmed it with a volt meter. The circuit is protected by a 30A fuse located under the hood in the main fuse box. My fifth wheel has two large 12V deep-cycle batteries. It also has a 120V residential refrigerator that runs off an inverter when towing (converting 12V DC to 120V AC). Assume I was camping without shore power and ran the fifth wheel batteries down to, say 50% charge, then hooked up the fifth wheel to the truck and took off driving down the road. The 12V auxiliary charging circuit is going charge the two fifth wheel batteries in addition to powering the inverter which is running the refrigerator. The fridge doesn't run constantly but let's assume that in hot weather it runs 50% of the time. Taken all together this load sounds like it might be more than 30A and enough to blow the fuse which protects the wiring - but in actual practice the fuse doesn't blow, the batteries stay charged and the fridge stays cold. So here's the question: Is there some sort of current-limiting circuitry in the truck, in addition to the fuse? Or is 30A more than enough to charge two deep-cycle batteries and run the inverter for the fridge?
