2012FlameRed1500
Well I purchased my 2012 Ram Express about 7 months ago. The only thing I did initially was install a used Mygig 430n that i got for a good price (had a 130RES without Uconnect), and I installed an upper glove box.
Within the last 2 weeks i've bought and installed a used 2012 EVIC cluster (mine didnt come with EVIC), the EVIC and voice command buttons for the steering wheel, installed Uconnect (module, harness, and mic), and the TPMS Module that goes behind the front driverside splash guard to get the individual tire pressure readouts to appear in the EVIC.
I'm planning go to the dealer on Friday to get some sales codes flashed/added to make sure everything works as it should.
I been searching around and wanted to confirm if these are the only ones I need. The first 2 i know for sure... but wasnt sure about the last 3 were needed or even matter.
RSP - Uconnect
XGM - Tire Pressure Monitoring module
RHB - Radio (430N)??
LAZ - Vehicle information center??
JAT - Instrument cluster w/display screen??
Thanks in advance!
RSP - Uconnect
Thanks in advance!
