93w150
Hey there
I have a 92 w150 that I put a 93 ramcharger 318 in. I converted it over to carb, and I’m dealing with an over charging issue from the alternator. Currently have a wire running from the alternator to the little relay blocks on the drivers side fender. That allows the battery to charge but the truck is pushing 16-17v to the battery. I know this model has an internally regulated alternator so I’m curious if any of you have had similar issues with a carb swap/ deleting the computer.
Thanks in advance!
Thanks in advance!
