Specs by VIN
j_a_wolfe
Burlington, KY
I-6
At one time there was a site which would allow you to enter your VIN and it would calculate your tow/haul specs based on the build sheet. Is it still around. I've looked but, no joy.
Thanx,
Jim
Mpgrimm2
Preferred Vendor
SC
2022 Ram 1500 (5th Gen)
5.7L
Thanx,
Jim
Also if needed ..
You can add your VIN (all CAPS) after the equal sign in the following addresses and hit enter (depending on the age of the VIN it may or may not work)....
For window sticker:
For build sheet:
I have been using the site below for years now
It tells you Everything that was ordered for that particular Ram
It may not have what was installed by
Ground Effects. Ltd or the Dodge Dealership
https://www.gfxltd.com/ is a Line-X & associates company, ( bed liners )
