Tailgate Latch sticking/won't open
spinxt
Doylestown, PA
HEMI 5.7
Does anyone know how to adjust the tailgate latch? I have to push forward on my tailgate just to get it to open (it will no longer open remotely). It's annoying. I searched YouTube and only found adjustment instructions for the old-style RAM.
Thanks in advance.
brian42
San Diego, CA
From what I understand you use a torx T-?? to loosen the latch bar/bolt that sticks out of the side of the bed then you can adjust it.
Elio
Florida - FLX Central NY
Hemi 5.7L e-Torque
Interestingly, I experienced my '20 RAM tailgate just (occasionally) act the opposite way. Once I drop it open, it won't close again!! it happened to 3 times already, and at each time I had to sneak a screwdriver and push in the metal tab (behind the latch) in order to close it. It took me awhile at first to figure this out while towing a TT and i could not afford let it loose on the hitch. The nearest RAM dealership would not let me in to inspect it, since I managed to fix it. However, on the 3rd incident I had to call Mopar and report this problem. Anyway, I should open a new thread for this and find if anybody seen this before.
soapy
Northwest
6.4 hemi
Ihave found that if you shut it firmly it usually will release every time. If yousoft shut it that is when you have the problem with it releasing.
Legrandmikiey
Oakhurst
Diesel
I also have a tail gate that’s stuck closed, on my 2020 RAM Laramie 1500. Been an intermittent problem, but now will not release to open. Any other ideas?
