Yes, that was crazy of me. Agreed, more like .1 to .2 at the most.
Brain fart.
I find old age gas may have something to do with it?
It's not a problem as my smeller is also buggered.
A test light would work to check for power at the switch, but the power must be OK as the latch works with the remote, and I presume when the doors are unlocked.
I just read some more replies after the fact, normal for me, see first line.
new switch don't work, i would think bad plug, or socket pins.
if you still had it at home, I would wiggle the plug and wire while pushing the button, if you never tried that, if you can get at the thing.
you can have 12v, but not enough current flow to pull the latch, I presume its a solenoid,
I presume it would be hard to check current with out chopping wire up.
or messing with jumper wires and probes.
