The stupid front driveshaft greasing....
lpfm1990
Newfane NY
Cummins 6.7
Ok, frustration level is off the charts.... how in the love of freakin god do you get grease into the ******** fitting, yes I’ve located it with ease, I see the indentation with a tiny hole in the center, I have the Lincoln needle fitting that everyone recommends... I’ve tried for a ******** hour and have grease everywhere but in the fitting and coming out the back side like I’ve seen on numerous YouTube videos... it’s like I need 3 extra arms to even do this. No wonder 95% of people don’t even try
lpennock
Phoenix, AZ
5.9L & 6.7L Cummins
Take the shaft off and do on a bench. Much less frustrating.
Sent from my SM-T350 using Tapatalk
lpfm1990
lpfm1990
Newfane NY
Cummins 6.7
That doesn’t sound much less frustrating to me, I can sense busted knuckles. Bolts, and frustrations getting it out and back in place
bdc2
Ks.
Go buy a cordless grease gun.
G. Mcpherson
Yacolt, Wa.
2023 Ram 2500 CC SB Tradesman
I purchased a Needle style Tip that can be inserted into the Center. Works good. I encountered the same problem as you.
68PowerWagon
Dayton, Ohio
2022 Laramie 3500
6.7 CTD
Yeah as you are stating, I can't tell if any is getting in the zerk or if it all is just running out. Seems to me that a normal zerk would fit into this area, why they insist on these is beyond me! Why not have a sealed unit just like all of the others?
I swear the first couple times I did it everything went fine, now I have no idea if any is getting in there. Does anybody know if the little ball in there freezes up? Would tapping it lightly with a nail & hammer maybe free it up?
22hemi13
Tucson AZ
2014 2500 4x4
Bahaha. I’ve thought about removing mine just to grease it good and give a closer look. Hmmmm maybe I’ll remove it grease and do it every other oil change. I’m sure there’s trucks that’s never been greased skipping an oil change won’t hurt it
mtnrider
Georgia
Since it's not a captive style zerk it's difficult for 1 person to do it with a traditional hand pump style grease gun (not enough hands).
Cordless grease gun is the ticket. Have done mine several times with ease and took just a minute.
Punishher7
My only issue is the leak where the needle meets the hose. MUCH more leaks out there than comes out of the needle. I asked the guy at the parts store about it and he said they all do it... Does the cordless grease gun fix this somehow?
JMod45
TX
6.7 Diesel
Pistol grip grease gun is a must, unless you have a second person to pump the grease for you. I've only done it once so far, and had more trouble finding the port than anything else. Held the point against that fitting really well, and greased until I saw it come out of the other end of the bearing. Didn't have much come out around the fitting that I remember.
This is the setup that I used:
https://www.harborfreight.com/Professional-Pistol-Grip-Grease-Gun-64381.html
https://www.autozone.com/grease-and...-gun-accessories/oem-needle-nozzle/141690_0_0
I bought one of these also, as I wasn't sure which fitting I was supposed to use, but never even used it since the other worked great.
https://shop.advanceautoparts.com/p/toughone-engine-grease-injector-needle-w54213/7070144-P
ALRedneck
Enterprise, AL
Ditto what JMod45 said. It’s not that bad with the hand gun and proper tip. I’m not a gear head and had no problems once I order the right tip.
Jimmy07
Instead of using the flexible whip extension, get a 6” rigid extension with a slight bend towards the tip. That way you can hold the gun body with one hand and the pump lever with the other. Jam the needle in there and pump away.
lpfm1990
lpfm1990
Newfane NY
Cummins 6.7
That’s what I was using [emoji23]
68PowerWagon
Dayton, Ohio
2022 Laramie 3500
6.7 CTD
I usually balance the grease gun on my stomach while I use my hands to pump & put pressure on the needle to the zerk. I still feel like more runs out the side of the needle than what actually goes into the bearings. :fca5278d:
lpfm1990
lpfm1990
Newfane NY
Cummins 6.7
I was trying that, using my forehead and a couple other contortionist configurations, and still got I think nothing into the damn fitting. It’s got me so irritated I still haven’t gone back under the truck to try it again... and the best part.... after I get this one done, my truck is waiting for it also (me and my dad both have 3500’s lol)
HammerHead
USMC 0313
Georgia/Florida
2019 4Runner
Bottom Line? I just had to muscle it to get it in. I was really surprised how much force it needed.
calinb
3.7 6-cyl, 6.7 Cummins
<snip>
It takes quite a bit of pumping but you'll know that you got some grease in there when it starts coming out other places than where you are pumping it in! Lots of good advice here but I'll add that I use a fully metal tip on the gun (not the rubber tipped adapters that work best on my chainsaw clutch) and if if any grease is coming out around the tip, press harder or move the shaft a touch to get a more square angle to it.
KarL45
Western Slope, Colorado
2018 Ram Express quad cab 4x4
5.7 MDS
Even my dealer couldn't find it or get it greased. Finally, took a short 12" steel brake line and adapted one end to small grease gun and welded up the opposite end with brass. Ground it into a point of about 1/32" at the tip and ground it back over 1/4". Drilled it out with a small size number drill bit. Now can get to the zerk. To see weather or not it is actually taking grease, you can look from the rear of the joint and visibly see the ring of grease appear as it fills the void.. Initial lube took just over two pumps to get it fully lubed. Probably not necessary on every lube but certainly worth the time and effort to do it I feel.
crazy jerry
WY
theres no bearing in there. is a ball and socket with rubber boot. unless its dry, one or two pumps is plenty. otherwise it squirts out the back and makes a mess. i use flexible hose and lincoln needle, nothing difficult about it
j winkelman
4.7 l
I have owned a 2500 and currently a 3500 dually...put a slight bend in the end of the tip of your grease gun fitting and you'll be able to do it without issue...to find it look for a slight divot..the divot before the actual grease fitting is pretty easy to spot
Sent from my XT1635-01 using Tapatalk
