tires
Donny04
Harlingen,TX
6.7 ******
What tires are best for the 2500 diesel 4x4. I live in south Tx where it's hot almost year round. Tires wore out within a year. Is this normal?
diymirage
2500 has a heavier frame then a 1500
Diesel adds what, 500 pounds?
4x4 (if engaged) wears tires quicker
But the real question is, how many miles did you put on it ?
Dean2
Near Edmonton
No details on use, miles driven, towing or not and a raft of other pertinent info. The OEM tires on a new vehcile last less than 30% of what that exact tire would last bought from a tire shop.
My suggestion. Search the word Tires, just in the title. There are 500 threads, 20 pages of threads, on the topic on here alone. If that isn't enough info, no idea what else to say.
Screenshot 2024-07-26 at 10-51-34 Search results for query tires DODGE RAM FORUM - Dodge Truck...png
Screenshot 2024-07-26 at 10-53-37 Search results for query tires DODGE RAM FORUM - Dodge Truck...png
CanuckRam1313
Ontario Canada
2023 Warlock SLT
What are your driving habits/conditions?
Mostly highway or off road - loaded and/or towing?
If you're mostly on-road, look at the Michelin LTX M/S (E-Rated) tires.
Regardless of tire choice, ensure you are regularly checking and adjusting your tire pressures, cold, and rotate often.
Tulecreeper
AZ - 83 Miles SW of the Geographical Center
OP didn't ask about the 1500
Diesel add about 900#
No one drives around in 4x4 mode on pavement, and the small %-age of the time it is in 4x4 is irrelevant
The mileage question is legit, though.
Tulecreeper
I have never found that to be true. And why would that be anyway, since they would be the exact same tires? Every set of tires I've ever had on any truck I've ever owned has given me at least 50,000 miles - including the factory set.
Dean2
Near Edmonton
I have never found that to be true. And why would that be anyway, since they would be the exact same tires? Every set of tires I've ever had on any truck I've ever owned has given me at least 50,000 miles.
Your experiences often vary from the rest of us. No idea what to say about why.
Do a search, there is a ton of documented evidence that OEM tires are made to a much lower standard to meet the price requirement to get the contract. Believe it or not, doesn't change the facts.
Tulecreeper
I simply said that hasn't been my experience, and was going to comment that maybe you just have more bad luck than average. I also don't recall anyone I know ever saying that their factory tires wore out quicker than any other tires they've purchased. Maybe the part of the country we have lived in, I don't know.
Dean2
Near Edmonton
Just one of hundreds of posts on this very forum.
diymirage
The point about 1500 vs 2500 is that if you look up "ram" most information will be slanted towards the 1500
Same with gas vs diesel
So, what he's gonna find will not likely match what he experienced
That's why I pointed it out
Units
Ms
2023 Bighorn
6.7l Cummins
I agree with @Tulecreeper. Everyone’s tire wear experience is going to be markedly different. No 2 people drive the exact same way and in the exact same condition's. For example, I’ve got 20k on the stock rubber on my diesel pusher and can easily get another 20k. To say all stock tires are complete garbage is not at all accurate.
Tulecreeper
As I said above, it may also have to do with the part of the country we live in. Areas that hit 110° for 4 months out of the year and drive on asphalt that is 160°+ are going to see different results than someone who lives where summer temps never get above 90. Same goes for winter temps. No driving in snow/ice is going to help.
2003F350
6.7 CTD
1. You guys might have scared him off, he hasn't posted since Friday.
2. To OP, this is like the dead horse of forums, usually searching the forum for tires 2500 gets you a bunch of info to search through before you ask a question like this.
3. Did anyone else notice in his info on the left that it censored his engine? LOL.
slbenz600
La Verkin
6.4 L
I have a 6.4L Hemi that I tow upto 10,000 lbs and our out side temp during summer time 105 degrees and winter down to 25 degrees so it gets hot and cold. I have ran Cooper tires on my gas and diesel trucks, currently I am running LT285/60R20 A/T3 Discover 10 ply 60,000 mile tire I rotate and balance every 6,000 miles. If you don't get at least 60,000 miles you need to have your truck inspected with 4 wheel alignment, my current tires have 65,000 plus mileage I will need a new set by winter.
