Towing without a towing package
Michaeli
South Florida
Hemie 5.7 liters V8 3.92 ratio
I have a Ram 1500 Laramie 2016 with a Hemie v8 5.7 liter 3.92 ratio, without a towing package. I have a hitch a two electric receptacles. Can I tow a travel trailer wight 6000 lbs ?
Thanks
Administrator
If your truck has the 8spd transmission (shift knob), it already has a transmission cooler. The rest of a "tow package" would include towing mirrors and the electric brake controller. There will be a slide lever on the center stack of the truck below the radio/HVAC controls if your truck has the brake controller.
You definitely need the trailer brake controller and a WDH to tow a 6K lbs trailer.
clay282
Black Betty had a child... named Betty White
Arkansas
3.6 Pentastar
If you don’t have the factory integrated brake controller… there are alternatives but they won’t work WITH the trucks stability control system. The OEM trailer brake controller can be installed yourself if your know a bit of tech and are handy with some tools.
nlambert182
Huntsville, AL
This.
The Laramie already has a Class IV receiver hitch, both receptacles, and trans cooler.
You can install the factory brake controller and get a flash to turn it on reasonably. Or, as some have said you could go aftermarket if you don't mind it not interfacing with your EVIC (cheaper option). Either way though I agree... you need a brake controller and WDH for a 6k lb trailer.
dhay13
Tow package did not come with tow mirrors. They were a separate option.
KeithP
Hemi 5.7 VVT
As stated above; brake controller of some type (EOM is best) and mirror extensions should get you set up to go.
2003F350
6.7 CTD
I'll echo all of the above, if you don't have it get the OEM brake controller and a WDH and sway control. If you don't have tow mirrors I would suggest either upgrading to them or at least getting a GOOD set of clamp-on ones, there are some out there that do a decent job.
Otherwise your truck shouldn't have an issue with 6k. Just take it easy and pay attention.
Administrator
According to the 2016 sales brochure the Trailer Tow and Brake group includes both. The other option was Tow Mirrors without the brake controller. The controller was also a separate option.
Usually when someone is inquiring about a vehicle "Tow Package" the options they're looking for is towing mirrors, receiver hitch, brake controller and transmission cooler.
clay282
Arkansas
3.6 Pentastar
He makes a great point. I do have a set of mirror extensions for hauling the camper. They are cheap and easy to put on and take off. Tahoe Q7i boat doesn’t need them or my flat trailer, just the camper. I never considered upgrading to the moose ear OEM mirrors because I park in the garage and I really don’t need the extra width.
dhay13
Can't speak for 2016 but my 2013 had the tow package and no tow mirrors and my step-father had a 2017 with tow package and he had to argue with the dealer to get tow mirrors. He told them tow package should include tow mirrors. They said it did not. He told them to put them on or he didn't want the truck. So can't speak with certainty but that's 2 with tow package that did not have tow mirrors from the factory.
Administrator
The '13 model year didn't offer a towing package, just the trailer brake and mirrors separately.
The '17 model year did offer a Tow package with both the brake and towing mirrors. From the '17 model year:
Seaholic
Saint John’s fl
If your trailer has surge brakes should not be a problem. I towed a 6000lb boat and trailer 800 plus miles round trip to the keys with a Ram 1500 /3.6 without any issues. Also the truck has the 3.2 rear end.
Curmudgeon
York, Pennsylvania
2014 1500 Laramie 4x4 QC, True Blue Pearl
Thanks
I'm curious as to why you say you don't have a "towing package", because it almost sounds as if you may have all the elements for it.
My 2014 Laramie 5.7L with 3.21 rear shows the towing package.
*Also I do not have tow mirrors, i have the "Gucci" mirrors that do everything else.
@Michaeli grab your V.I.N. and plug it into these sites, one for your actual window sticker...
And one for your Equipment Listing from Mopar...
Use ALL CAPS at both sites. Hope this helps.
EDIT: If these details matter, I also have the 8-speed trans, quad cab, 6ft bed, electronic brake control.
Jack F
Mississauga,Ontario,Canada
Pentastar 3.6
Thanks
i'd rather take it to a dealer and install the electric brake control,it's the perfect job and your dash will look kleen,no drilling,no screws,it's a litle expensive but i guess that's the way to go,in Canada it cost me $800,in US it has to be cheaper
Jack F
Pentastar 3.6
Clean
markabby
Monticello, Kentucky
2020 Limited
if it came with the hitch and a 4/7 plug you can easily add a brake controller. i bought mine off ebay, it took maybe 30 minutes to install and i had the dealer add it to the computer.
towing 6000 pounds you want brakes on that trailer (if it has them) because all that braking force will be on the truck now and they'll wear down and heat up faster.
Jack F
Pentastar 3.6
I had everything but the brake control,also replaced my coil springs with ones one inch and a half bigger,now towing 5000 lbs travel trailer is a breeze
2003F350
6.7 CTD
A lot of it depends on the dealer and what they charge. For my wife's old Ford it was only like $150-200, on her 1500 it was closer to $400 I think. BUT the biggest advantage to having the dealer do it is that they won't put in the wrong part, they will only install the one that their parts lists call for.
Tulecreeper
Sthrn AZ
Basically, for 47/50 states trailer brakes are required for trailers 3000lb or more. For Kansas, 2000lb, and for Nevada and California, 1500lb.
