Tranny issues
Kmken
California
Have a 91 dodge ram van B250 5.2 318 just replaced the torque converter and the position crank sensor will go into rev but not d or 2 or 1. Plz help its not a fluid issue
Skatulaki
Green Cove Springs
5.9 liter 360
My guess is that something in the linkage was not put back together correctly. Check the shift cable and the linkage, As long as you have not dropped the valve body, you should be able to cycle the gears by hand, and move the shift lever to the right position.
BillsRam
