abates362
Having some weird symptoms and can’t pin point.
Flat ground, very slight head wind, highway speed. Cruse control on. Transmission temp not quite operating temp. RPM’s stay steady, until downshift to 7th. The truck will shift to 8th and my L/100km will slowly creep up from 15 to 30L/100kms then down shift to 7th again.
It will do this until the trans gets to about 50-60C and then runs like normal and will hold 8th gear all day even on slight inclines.
It will do this in tow haul, does it in eco mode.
Has anyone else had weird symptoms like this?
