paulmatthees
Hello, this last weekend me & the wife were at our family property pulling a little utility trailer full of topsoil filling in holes from pulling stumps & other holes on the property. When we to the area I decided to put the truck in 4 low to better move the trailer around where we needed it & not spin my tires making more holes to fill. We got done doing our work & when I got back onto a flat gravel area to leave I put the truck back into 2wd and turned the truck off. We closed up some sheds & secured the property then hoped in the truck to leave, after I started the truck I tried to put in drive & nothing, the dash was saying truck speed to fast to go into drive, then I tried to put it into park, same thing except I could hear like the parking pin clicking in the transmission, then I tried reverse & it worked fine. I tried a few more times & same thing. I finally put it back into 4low & drove around the property a little bit & then put it into 2wd. After waiting & checking everything I could I started the truck & put it in drive, luckily it worked, we left the property & got about 2 miles down the road & heard a whinging noise. I pulled over to see if anything happened, no oil leaks, no broken parts, nothing. By this time its getting late & decided to drive home. Everything worked perfectly on the 55 mile drive home & checked the truck this morning, no leaks or anything. This worries me because I don't want my family stranded anywhere & I have no clue of what it might be. Any help with the potential problem would be greatly appreciated so I can get it fix. Thank you
