Triax trans fluid for 8hp
caulk04
For those who'd rather stick to a factory fluid in the ZF trans, we've seen that it's quite expensive (Mopar) or somewhat hard to find (ZF Lifeguard). The other option is Maxlife which is easy to find but a very broad spectrum fluid, not having that argument here.
Anyway, Triax sells this fluid which is listed specifically for ZF applications and cites all of the Mopar part numbers for 8/9 spd fluid. At $57 shipped for 6qt and arrival in a couple days, both problems are solved. Also of interest is their fluid shares the same light green tint as the factory Mopar fluid.
Food for thought, nothing more.
EdGs
FL
That's definately worth looking into, especially if they list the compatibility.
I had a '97 Audi A6 quattro that had a ZF trans in it. ZF trannies used in ALOT of vehicles over the years, for sure.
Burla
2010 Hemi Reg Cab 4x4
They don't label stuff like bitog is used to because they concentrate on fleet stuff. if it works it works, with the 8 speed you know if it slips or not. Even the mightly redline has issues with the 8 speed, too slippery. We have a handful of triax users around here, they seam to like it.
caulk04
caulk04
Source or bs. I looked briefly and the only recurring topic I saw was an argument about a gear oil.
I've used bitog for information because there is good info there, however it is a hub for the oil freaks from EVERY forum to congregate
ramsare4real
FL
It's the home of the lubrication experts. It's up to you whom to listen to.
