neicyTX
Instead of pulling my hair out, decided to try and post here for a possible answer.
I purchased the Uconnect map update from HERE a few months back. They sent the update which contained two thumbdrives... one for System update and a second thumbdrive with the map update. Instructions are clear about being sure to install the system update cuz failure to do so could screw up the system.
So, I follow the instructions to insert the thumbdrive for system update into a USB port 1. The trick is figuring out WHICH of the three different USB ports is USB 1. There is one below the AC port so I figure it was that one, but there are also two inside the center console. Doesn't seem to matter though as NONE of them cause the "Start Update" dialogue box to appear on the screen. I have watched some Youtube, read some posts in numerous forums, and learned that the USB must be inserted BEFORE the truck is started. Tried that; didn't work.
So I call HERE which sells these updates and they were stumped as well, so they sent me replacement thumbdrives. I put it off and put it off and decided to try it again today. Same result -- different day.
Anywho, has anyone been able to successfully update their system. Any advice as to how to get the update screen to come up?
Instructions I've been using are below.
Quick Start Guide
Installation Guide
Thanks for reading this post and look forward to hearing if anyone else has had the same issue.
Denise
Quick Start Guide
Installation Guide
Denise
