Artie L
I have the 12 inch touchscreen with Nav. system with the Alpine speakers. Can I add more power to those speakers with an amp?
You can look on crutchfield they have adapters that you may need. Im not sure if the Ram is the same as the challenger alipine system. If it is the speakers are all 2ohm and not 4 ohm which makes it a issue if you want to replace them. I was going to in my wifes 23 challenger with the alpine but decided it was not worth the hassle. The alpine does not sound good at all. My Ram has the base audio system i a month or so I will be adding a subwoofer.Yes in some instances and no in others. Best thing to do is work with a trained stereo technician to match what you have to the head unit and speakers. Nonsense spending money for a subpar unit.
^^^ THIS!!!!!!Yes in some instances and no in others. Best thing to do is work with a trained stereo technician to match what you have to the head unit and speakers. Nonsense spending money for a subpar unit.
