Upper Control Arms
Orange_Ram
New Jersey
Quick question.
Would zone's upper control arms work/fit if im running a BDS 6 inch lift? I just ordered the BDS upper control arms for the 4-6 inch lift but I am not sure if they were worth the almost $800.
Nick@GotExhaust
Preferred Vendor
SC
Do you have any additional lift, other than the lift kit itself. For instance are you also running ride height adjustable struts or coil overs? If not then the Zone ones wont work as they are angle correcting for 2-3" of lift(non bracket lift)
mrack
You know more about lifts then I do, but zone specifies their upper control arms are for either the 6” lift kit or a 2” level, but not the 4” kit as that retains factory geometry. Since of course Zone and BDS are very similar kits I believe the zone arms would work fine on a 6” bds.
That said I would recommend JBA over zone, they are fully greasable with a bolt in ball joint, and they don’t mess up your alignment like Zone arms. Also have more clearance to the tire if that’s a concern for your setup. Little bit more $ then the Zone arms, but they’re a great small business to support and still cheaper then BDS which are way overpriced IMO. I’ve personally run both Zone and JBA and JBA are definitely the better option. Just make sure you get angle correcting and not the stock geometry version.
Nick@GotExhaust
Preferred Vendor
SC
They do use a pre load spacer along with the spacer for the lift but I feel it is still not enough lift to run a angle correcting UCA properly. The pre load spacer only adds 1".
I would recommend the Core 4x4 UCA's. They are made specific for the amount of lift you have
O
Orange_Ram
New Jersey
I am pretty sure I have the coil overs. Thank you for the information!
O
Orange_Ram
New Jersey
Yes I was made aware about zone not working for 4 inch lifts. And funny enough after looking all over for UCA's JBA was popping up for me but I did not know if they were reliable or well known. Is is their website?
To add on. Yes in my opinion BDS does seem to be a bit overpriced but the shop where I decided to go to recommended me to get them since I am already running the BDS lift kit. The hardest part is just waiting the 4-6 weeks they said for the parts to arrive. It also looks like JBA UCA's are 1 to 3.5 inch lift kits.
mrack
Yep that’s their site. JBA has been around a long time and they really know their stuff.
O
Orange_Ram
New Jersey
So next question is, are your coil overs cranked up to add lift?
That is a good question. I am not sure to be honest, how can I tell if they are??
Also can I get opinions on the readylift UCA's?
DILLIGAF
Canada
Core 4x4 UCA is what you're after !
Nick@GotExhaust
Preferred Vendor
SC
post a pic of your strut/coil overs. Lets see what you actually have in there 1st. Then we can try to figure out height and what UCA's would work with your set up.
BlackSheepRebel
The Matrix
Lots of good info here hard to go wrong with JBA or core just be aware of threads where some complain about wheel offset not being compatible with core. I think they were fixing that though.
O
Orange_Ram
New Jersey
Sorry for being late. But here it is.
O
Orange_Ram
New Jersey
Yes it is very good info. I am doing my research on each. But I went with readylift last minute.
O
Orange_Ram
New Jersey
Also, I have these coils in the rear. I noticed the rear is an inch or so higher than the front. Could it be the RC shocks I have in the back or the coils that are causing it?
Thanks in advance for all the great information and details.
olyelr
Kewadin MI
The shocks have nothing to do with ride height at the rear. Its the coils. Is there a spacer above or below them?
The front looks like the original struts with a spacer, so very possible the rear springs are stock with a spacer as well.
Looks like you are due for tires…those things are quite weather checked!
Quick_Shifter
IG: @ak_trucks_pa
TOTY Winner
ASTON,PA
AK Trucks Tuned 5.7
Post more pics. How do rc shocks end up on a truck with a BDS kit?
Let’s see the cross members in the front.
Since the angles on your UCA’s look good now and you’re being budget conscious with your decision I would run the mevotec UCA’s they are tried and true. They will be your best bet and leave room in the budget to replace the RC shocks in the rear
O
Orange_Ram
New Jersey
Thank you for your response. And yes I will be changing them soon. Are toyo open country mts better than nitto trail grapplers I have currently?? I have 35X12.50R20 for reference.
O
Orange_Ram
New Jersey
Well I have no idea what upper control arms the previous owner had on the truck but I went with readylift and I will provide pictures tomorrow.
I went with rc rear shocks bc I did not know a lot about rear shocks I thought they were my safest bet.
Also a little backstory with the UCA's:
I got the truck back Saturday and the alignment shop said the truck drove to the right a bitr I thought it was a bit until I drove it home and I realized it was a good amount. Today I took the truck back to the shop and explained the problem to them. they said when they were aligning the truck they had to move or adjust the right side caster all the way high / max spec. So what they did today was adjust the left side caster (driver side) by lowering it. This helped alot with the truck so now it only goes to the right a bit. maybe its a tires issue now? Sorry for the long response.
Quick_Shifter
IG: @ak_trucks_pa
TOTY Winner
ASTON,PA
AK Trucks Tuned 5.7
Put the passenger side tire on the drivers side or rotate all 4 in an x pattern.
Caster is not a live measurement so they should have done a few caster sweeps while doing the alignment. If you were decently out they would need to roll comp the truck to get more realistic numbers. I would find a different alignment shop. Tires are too expensive to get it wrong and your truck ride better than factory minus the rear shocks
stevo5441
