Elk-A-Holic
2006 Ram 3500 4wd 5.9i diesel 80,000 miles
Truck became hard starting--cranked excessively before it would start but ran good after it got going. Replaced with rebuilt injectors and crossfeed tubes purchased from Western Diesel in Winnipeg. Truck then started good but smoked like crazy . Used block off tool on fuel line and determined that injector #4 was stuck. Western replaced on warrantee but I did the work. Truck started and ran fine for about 600 miles where it started pinging and smoking. Blocked off fuel line to cylinder #1 and determined that was the stuck injector. Phoned western Diesel and was told I had dirty fuel and must drop fuel tank and flush out fuel tank and lines. (of course fuel tank was full). So did that but fuel tank was clean as a could be. Absolutely no visible contaminants. So suspecting faulty rebuilt injector I replaced #1 injector with a new Bosch. As I had the fuel tank off I also replaced the lift pump with one from Rock Auto. Now truck starts easily and runs well at an idle but when RPM gets up to around 1500 a whisteling noise develops and the engine looses power. Check engine light comes on. code P0148 which I understand is a lack of fuel getting to the high pressure fuel pump. Could the noise be from the pump cavitating? Noise seems to be coming from Left side and front of the engine. Cannot find any air leaks in the turbo air intake . Any suggestions ?
