Window switch driver side.
Truckingjd
Tennessee
My window switch driver side just quit working for the two front windows.The switch does work for the two back window.Anyone thinks the switch went bad or something else?
I passenger side switch for the window works fine also.
markabby
Monticello, Kentucky
2020 Limited
remove it and see if it's receiving power and sending power to the window lift
or, go to a salvage yard (or buy a new one) and see if that fixes the problem
if it's sending power, then the next issue might be with the motor itself
RamDiver
Marlborough, Ontario, Canada
Has any work been completed recently on that door, under the dash or elsewhere?
And, chrome_image_Nov. 16, 2023 4_51_54 a.m. EST.png to Ram Forum. :cool:
tron67j
Maryland
So the rear switches move each window? Did not quite understand. If yes, quite possibly the switch if you didn't do anything like move wires, remove fuses or take door panel off.
If switches don't work in back, could be the motors.
T
Truckingjd
Tennessee
Yeah was working fine and stopped for gas and went to roll it back down and nothing happens.
Tom Davis
Colonial Beach, VA
5.7L
Had the same issues, except mine was down and would not roll back up. Ended up replacing the switch. Forget what I paid for it through Advance Auto, but it had a core charge of $100. I popped it out and took it in with me to avoid that, and put the new one right there in the parking lot. Simple easy fix.
