2001 ram 1500 5.2l
ghoulex345
North Carolina
Magnum 318
I need some help I’ve got a check engine light code for evap leak and I don’t know where to start to look
Black-Wolf
North Carolina
Specific code would help - and EVAP leaks can be caused by something as simple as your gas cap not being tightened enough, or cross-threaded. Old gas caps can have the seal degrade. If you put a non-OEM cap on, and it's not a good match - that could cause this.
A quick search for "Evaporator Leak" turned this up.
  • Your gas cap is either loose or incorrectly attached
  • Your gas cap does not meet vehicle manufacturer standards
  • You have a tiny leak, crack or hole in a fuel vapor hose or tube
  • You have a different type of leak somewhere in the EVAP system
  • You have a faulty vent or purge valve
  • You have a bad vent seal
  • You have an unreliable leak detection pump in the EVAP system
Without more info - it's hard to diagnose or tell you where to start - but I'd start with the gas cap.
Note: It will take two or three days of driving (or about 50-60 miles) to clear the code if it was the gas cap!
RodeoRam
North Carolina
If the gas cap is not the culprit (it never was the source of the evap leak on my 2001), get your system smoke tested. The Meineke in Greensboro did mine and found the leak in the hoses between the evap canisters that the dealership from almost day one of it being brand new couldn't/wouldn't find.
