MuddyJeep810
Hi all. New here. Just purchased my first Dodge Ram over the weekend. It is a 2006 1500 SLT crew cab 4x4. I am interested in adding fog lights to my truck. I currently have the angled 'filler' bezel in the fog light location in my bumper. I found the factory wire harness on the drivers side that the factory fog light pig tail would plug into. I have read that the 2006+ needs to be programmed by a dealer to enable the fog light feature. I also read in my truck manual that if my truck were equipped with fog lights it would have a headlight switch that can be pushed in to turn the fogs on. I do not have that switch. My existing headlight switch only rotates, it does not push in, pull out, or indicate fog lights whatsoever on it. With that being said, when I turn my headlights or parking lights on the fog light on indicator symbol in the instrument cluster illuminates. This light goes out when I turn on my high beams.
I have a few questions for you guys.... It is my understanding that I need the pigtail to connect the factory harness to both fogs, fog lights with brackets (left and right), and I am presuming the bezel without the angled filler pieces to complete the installation up front. Is this correct?
Also, do I still need the headlight switch that has the fog light on/off capability to use my fog lights or does the fact that the indicator on the dash evidence enough that my current headlight switch will work just fine (assuming I never want to shut them off when the headlights or parking lights are on)?
Finally, seeing as the dash fog light indicator turns on and off as if fog lights are already connected does this mean I may be able to connect the fog lights and they will work without a dealer flashing the code into the computer?
Thanks in advance! I am really loving this truck so far!
