2013 Ram 1500 won’t start or hold a jump
Shteven401
Massachusetts
So I was driving on the highway all of a sudden truck would not accelerate lost power steering and lights started going crazy. I pulled over shut it off tried to restart and it all I get is a click and won’t turn over. Now battery is completely dead tried jumping it. Lights came on then the dash lit up like a Christmas tree every single light and truck still won’t start and the battery is completely dead again. Is it the starter alternator battery or did my engine seize?
There’s been a ticking and when the truck did stop working while I was driving I did smell a burning sent and my transmission isn’t reading any temperature and just all the lights start flashing like crazy and then the battery is completely drained.
Just tried jumping it a few minutes ago and did the same thing lights went crazy I used a multimeter reader and battery is showing barely any voltage which I asssumed because it was completely drained while I had it connected to loaner car volts were at 12-13
tron67j
Maryland
O had an immediate battery failure once, ran fine into a driveway and then restarting 5 minutes later all went haywire. It was a broken plate inside the battery. From your voltage issue, your battery could be the culprit.
S
Shteven401
Massachusetts
Thanks guys I will switch the battery and go from there just trying to save the trip to the mechanics and get charged for something that could be a simple fix. Not very mechanically inclined so figured I’d reach out here before getting the run around.
Daw14
Clean the terminals also while it’s disconNested .
