2017 Ram 1500 Loose Power Outlet
Wildbill1
Missouri
The power outlet on the passenger side dashboard is very loose and imtermittently losing power. I can't figure out how to get it out or tighten it. Anybody else have this issue?
GTyankee
El Cajon Calif. 92021
3.0 ecodiesel
First thing to know, if it is the 115 vac outlet ??
the module is mounted on the passenger seat frame, just under the seat cushion.
I do not know if removing the Lower Glove Compartment, allows you to get to any screws that hold the outlet in place ?
YouTube has several videos, that show how to remove the dash bezel that holds the radio & 115 VAC outlet
