ramffml
- Jul 12, 2019
- 2,925
- 5,488
- Location
- ramforum
- 2019
- hemi 5.7
The 10 speed can save fuel over the 8 speed because there are times when the engine can drop 200 rpms and still carry the required load. However dropping 400 rpms might be too low and then you're lugging so the truck has to pick the higher-than-needed gear/rpms. If you have 10 gears, you have more possibility to drop RPMs. That's where the fuel savings come from, you have more ratios to choose from but more importantly they're closer together so you have more ability to drop RPMs.
The 3.21 vs 3.92 is different because at all speeds above (roughly) 15 to 20 mph you're always at the same RPMs in both trucks. That's what we're trying to tell you. Once you're off the line, at no point in the city/freeway is the 3.92 running any significant different rpms vs the 3.21. You're just using a different gear number in the transmission but your engine is still turning at the same speed. And then of course once the 3.21 hits 8th gear its game over and the 3.92 will never match the fuel savings of the 3.21 in 8th.
