5th Gen 2019+ Foglight Add-on harness
abbylind
Hello
Looking for the BCM cable to finish my LED fog light install
Thanks!
Mpgrimm2
Mpgrimm2
Preferred Vendor
SC
2022 Ram 1500 (5th Gen)
5.7L
Hello
Thanks!
Sent you a message with details to get started.
Mpgrimm2
Mpgrimm2
Preferred Vendor
SC
5.7L
Message sent
Mpgrimm2
Mpgrimm2
Preferred Vendor
SC
5.7L
Message sent
JustARam22
Just completed this mod, harness worked great.
Couple of things that are different then the install videos I ran into.
1. Run the bumper Harness along the bottom of the bumper not in the middle as shown in the video.
2. Remove the ANC model under the dash. it takes a few minutes but we'll worth it, it will allow you to use 2 hands while working under the dash. I can post pictures of anyone is interested.
3. The bypass used in the video for the 2500HD isn't the best one. Your better off purchasing the bypass that installs behind the cluster to give more features of alphaOBD incase you want to make future changes.
Meodom
Greenville, SC
6.4L Hemi
I'll take all the tips and photos you can share.
JustARam22
I'll try to get you some photos later today...
I actually watched this video from infotainment that helped out alot. The module you are looking for is the one on the firewall, back left corner driver's side.
If you watch the video they will reference removing the ANC module which is the aluminum box with heatsinks that makes it really hard to get 2 hands in there. The ANC module is held in with 1 10mm bolt and 2 8mm bolts once you remove it just unplug it and move it to the side. This will give you a lot better access to work.
Meodom
Greenville, SC
6.4L Hemi
Just wrapped it up. About to do the alohaobd programming now. Got it done in 1.5 hours. Wasn't as bad as I was expecting.
Thanks for replying!
boomer_rich
2022 3500 DRW
Cummins 6.7L HO
I'd like a harness for my 2022 ram 3500 tradesman
Mpgrimm2
Mpgrimm2
Preferred Vendor
SC
5.7L
Got your submission on my site... Will reply back later this evening (out and about at the moment)
PCT
2019 2500 6.4
Northern California
Was going to make my own post about this. But figured it could be a decent FAQ?
I finished this entire install. Drive dog turns on, good to go. Passenger does not.
When I turned it on non of them were on, so check polarity, driver turned on passenger did not. Swapped bulbs with a spare I have, same thing.
What would cause passenger bulb to not turn on?
