6.4 hemi Coils and plugs
heavyhemi55
wisconsin
6.4 hemi
I am trying to find the best spark plugs and coils for my 2018 6.4 hemi! There r a lot out there and witch is the correct ones for performance!
Jim BB
Hamilton ,ON
2019 Ram 1500 classic Express
so are you you saying factory (OEM) plugs from dealer?
Daw14
You can purchase the factory plugs from other than the dealer and save lots of $$. No need to change a coil except if it is defective,and then the OEM is a very good product and you won’t find gains with others.
Just don't buy plugs off Amazon or Ebay.NGK's are one of the worst plugs to be fake from either site.
You won't find any hi-po shops using after market coils on any build making north of a 1,000 hp,they all are using stock coils..
You can rebuild your stock coils with new rubber boots and springs,and use a dremel with a carbon steel brush to clean up the contacts under the springs. If your rubber boots and springs are in good shape,you can just pull the springs out and give them a quick wire wheel cleaning on a bench grinder,i also stretch the springs out about a 1/4" if i'm re-using the stock boots and springs after cleaning the springs.
