8.4 an ra4 Navigation
Scorpio6
Ocala
5.0 Hemi
My Navigation has gone out again Infotainment says its the Sierra Air Card Does anyone know which one I should purchase and where to get it from 2014 RAM 1500 Laramie Longhorn If I put a new one in, is it plug and play if all my software is up to date?
GTyankee
El Cajon Calif. 92021
3.0 ecodiesel
So you went to Infotainments Repair shop & they told you that ?
What happens when you press the NAV button?
Does the Map come up?
I don't know much about how the Infotainment System works, but i would guess that your Systems software is a version or more behind where it should be
your radio is basically a computer, the Air Card is a Daughter Board that is attached to the radios Motherboard by mostly soldered connections
check this out, before you change your Air Card inside of the radio
by the way, Infotainment.com has a repair service in Florida
not far from Orlando
Administrator
Don't think the Sierra Air card is easily sourced/replaced.
You could just find another 8.4AN radio and swap the whole radio(it's Plug-n-Play).
Mpgrimm2
Preferred Vendor
SC
2022 Ram 1500 (5th Gen)
5.7L
A 2013-17 Ra4/VP4-NA Nav radio will be plug n play and can be found in fairly nice condition on eBay & normal salvage yards/ sites like LKQ, Schram, Car-Part, etc. If you're looking for the easiest replacement, I'd recommend a 2017 Ra4 (PN: 68270661Ax) or a 2014 unit if you prefer (68224525Ax).
- INFO- 2013-2018 8.4 FW Notes (RA4/VP4 & UAx NA)
* There are other upgrade options that are more involved.
S
Scorpio6
Ocala
5.0 Hemi
My Radio software is Up to date. I checked that first. I have done a factory reset of the radio and waited for 72 hrs to no avail. If the air card is soldered in I probably can't do that myself. to tedious. I am looking for a total replacement as well Not the 8.4 AN RA4 because of the sierra card This last one only worked for 3 years or maybe a little less. At $400 a repair that adds up in truck maintenance Thanks for the Help!!!
S
Scorpio6
Ocala
5.0 Hemi
Sooooo, After about 6 days My Navigation is working again. Thats what always happens. Getting the Height10 radio installed on Wednesday. Will let yall know how that works after I run it for a week or so
SitKneelBend
St. Louis
3.6 Pentastar
I'd be interested in a review!
