9.25 Chryco
Dan Dukes
Missouri
Hello all, Ive never set up a rearend or anything and I was wondering how to install a new ring and pinion on my 83 w150. Im hoping someone knows of some links or diagrams. Something i could use to do this. The rear diff has new everything but the mechanic who did it said the old ring and pinion would need to be replaced to mesh up l guess and i cant afford to have it done by him so wanted to tackle it myself and hopefully not destroy the rearend all over again.
Dan Dukes
Dan Dukes
Missouri
Is there another year model rearend i could get at a scrapyard thatd be a direct replacement? Im not positive what gear ratio mine is but i know itd have to match the front and all. Ive watched a few of those videos. Thanks
Dan Dukes
Dan Dukes
Missouri
Or would getting a matching set off a newer truck with a differnt gear ratio work also? I suppose it would but im not positive.
Dan Dukes
Dan Dukes
Missouri
Will 2001 3.55 gear ratio axles work for my 83 w150?? I found some for 150 each.
Sorry for all the dumb questions.
reek
Sacramento
2015 RAM 2500 CC 4x4, 72 D100, 73 D100, 01 RAM 2500 field truck
as long as you match the front and rear gear ratios, any ratio will work.
any 1972 - 1993 rear axle will bolt up to the truck. However, the wheel bolt pattern went from 5 x 4.5 to 5 x 5.5 I THINK around 1982 or so. So you'd have to swap axles shafts if you do go with an older one. I don't have much experience with the front axle but would have to assume that would bolt over directly as well. The frame and suspension on the 72 - 93 trucks didn't really change much at all.
3.55 is a good 'everyday' ratio but I don't think a 2001 will be a direct bolt on.
crazzywolfie
under the truck
you may want to verify the front gear ratio first but the more common ratio was 3.23 in trucks without overdrive. 3.55 only became very popular after 89-90 when they started using overdrive.
Sherman Bird
Houston, Texas
That Dana 44 is very practical and durable.... and very easy to work on. You do not necessarily need to replace the ring and pinion just because they are used. Your final mesh pattern is what counts. Also, be VERY careful where you obtain parts.... there are some real sub-standard pieces out there!
EvilSpirit
5.9 Magnum
Something to consider on a front axle swap is what year did they switch from the 1 piece passenger side axle to the 2 piece axle with the engagement coupler?
