AlfaOBD TV
SitKneelBend
St. Louis
3.6 Pentastar
Reposting info here in a separate thread with more detail for anyone interested...
2 LockPicks have failed on me so I won't go that route again. I had every input on the LockPick in use so I was left with a Digital TV tuner and front/cargo/left/right cameras inoperable.
@Mpgrimm2 let me know about some tricks others on the forum had figured out to get a front and/or cargo camera working using AlfaOBD.
So I've run switched ACC power to power all of the aforementioned accessories and I have a (cheap) manual RCA switch which shipped quickly by air from from Korea...
RCA switch
I've turned on the cargo camera with AlfaOBD and used @Mpgrimm2 's $20 camera harness for video.
AlfaOBD Cargo Camera Settings to enable:
VehConfig 1 - CHMSL Camera
"Yes"
CBC Features - LED CHMSL Lamp Present
"Yes"
If you stop here, you'll have a working video input on the on-screen cargo camera button.
I then removed the factory pins for the radio AUX input at the back of the radio and inserted my own re-pinned RCA Jack's for right/left audio on pins 6/7 respectively...
I now have left/right audio and video for Digital TV on the 8.4 screen.
DTV
To watch TV, I currently select the AUX input for audio and then switch to the cargo camera (and I wait for my wife to come out of Target). I probably could have left the factory AUX jack useable by just tapping them for my audio, but I decided that was more than I cared to try after discovering I no longer even owned and AUX cable.
I use the cheap switch which I placed in my glovebox for now to leave it on front camera for most of the time...
Front Camera
But I can also select the other two cameras or DTV if needed without opening the dash up...
Cargo Camera
Right Mirror Mirror
Costs
Cameras used (front/left/right) $17 each
CNGATE Front Car Camera |360 Degree Eyeball CCD Waterproof Front Car Camera with Wide Angle https://smile.amazon.com/dp/B00AWRAYA2/ref=cm_sw_r_cp_apa_i_uFzrEbQB6Y9Y6
Mpgrimm2 RCA harness (x3 if you want video/left audio/right audio) $20 each
DTV receiver (this one gives you an extra input) $50-$70
https://www.ebay.com/itm/Pyle-View-...44720.c10&nordt=true&rt=nc#vi__app-cvip-panel
This is the smallest/cheapest video only RCA switch I could find $20ish...
https://www.ebay.com/itm/4-Port-SIN...1?pageci=e9fa0da2-1c5b-4632-a89e-5e3a45b702a2
There are many options for the cargo camera and I no longer would recommend the one I'm using because while it is good it has more than doubled in price since I purchased it.
That's it! Much cheaper and likely more reliable than a LockPick! It was $50 to have the first LockPick replaced UNDER WARRANTY!!! You can get AlfaOBD for that much! AlfaOBD wins again!
likes2build
Mohawk Valley, NY
2018 Express RCSB
3.6 Pentastar
RCA switch
"Yes"
"Yes"
DTV
Front Camera
Cargo Camera
Right Mirror Mirror
Costs
@SitKneelBend was the shipping for the RCA switch $35 when you bought it or is it Covid surcharged? I'm getting ready to do this mod and was just wondering.
SitKneelBend
SitKneelBend
St. Louis
3.6 Pentastar
Nope, I paid $3.00 shipping from Korea ($21.24 total). There used to be Digital TV Tuners with additional inputs for around $60. I wish I would have bought one of those instead. Might be worth looking into for your application.
likes2build
Mohawk Valley, NY
2018 Express RCSB
3.6 Pentastar
I thought it might be covid surcharge, I see a lot of that in shipping from overseas lately. I'm looking more towards the multiple cameras and not the TV. M2Mods did the radio RCA tap harness and I already used your directions to turn the second camera on. The switch you posted looks really nice and compact with no extra RCA's in it other than what I need. Mike and I talked it over and I'm going to use one or two of the inputs for wireless cameras on my cargo trailer. I'll keep looking for a switch, $35 to ship a $16 switch is stupid.
SitKneelBend
SitKneelBend
St. Louis
3.6 Pentastar
Agreed! If I come across one I'll be sure to let you know.
oldmitch
NM
6.7L cummins
I'm assuming the "lockpick" is a way to add video inputs? Does it also circumvent the automatic screen change, while driving? Is there a way, in alfaodb, to turn off the auto-off feature for the camera input?
SitKneelBend
SitKneelBend
St. Louis
3.6 Pentastar
It used to but I don't know if it still does. It never did it well for me either. If I had the option on and went to reverse then drive it would make the NAV think I was driving backwards.
oldmitch
NM
6.7L cummins
Huh. I've been snooping around all day, looking for a wiring diagram for the radio. There's got to be a wire that tells the radio the vehicle is moving. If you could interrupted that signal, then the video inputs would stay on indefinitely. That HAS to be how those lockpick things work right? I mean they don't have any programming that takes place? Although, if one was able to figure that out - like the lockpick folks - the same issue you had might arise. There's gotta be a way though.
Gixxer750
N. Idaho
2015_2017
Yes, the lock pick as far as I'm aware was originally used mostly to enable video while in motion. I could be wrong, my brain seems to have fused the lock pick and watching movies while driving
Gixxer750
N. Idaho
2015_2017
I know where the setting in alpha obd is to disable the screen cutout, but progressive snapshot has me locked out of my obd2 port for a few more weeks
Administrator
The wire that sends the "signal" to the radio that the vehicle is moving is via the CANbus interface, without that the it can't communicate with the BMC/HVAC controls either.
As for the Lockpick it utilizes hardware and software to reinterpret the information the radio receives. The Lockpick has had several firmware/software upgrades to resolve issues specific to different model years.
oldmitch
NM
6.7L cummins
I would VERY much like to know where that is! OR what it's called at least. I fiddled with mine for a while, and for some reason my alfa will not connect to my radio... kind of. The only things I can mess with are the "audio amplifier" and "(ICS) MY2013+ Powernet". everything else times out.
oldmitch
NM
6.7L cummins
I see. From the pictures of them that I saw, It looked like just a harness; no brains.
Gixxer750
N. Idaho
2015_2017
It will be a while but once I can plug my obd link back it I will post it. Im going to be adding the bed camera and I want to be able to have it on more than the 5 secs that it will allow in motion. Also I'm going to enable the disc player option so I can get my phone mirrored to the screen. This progressive snapshot thing is really starting to bug me. The website says: "you're on your way to a big discount for your safe driving habits. We just need to gather a little more data. Please leave the snapshot device plugged in until we notify you. There will be a penalty for removing it in the first 45 days."
chri5k
USA
Diesel
I did the snapshot thing. I removed it to do some Alfa work and they never squawked. I think it doesn't matter about removing it if the engine isn't running. Also, the savings were not that big. About $45 per vehicle. It seems they use an accelerometer to measure acceleration, braking and turning. The stats I see that make up their "score" are all related to those factors. The kids did have fun bragging about whose score was better though.
oldmitch
NM
6.7L cummins
Tell me more about this "disc player option"!?
oldmitch
NM
6.7L cummins
Also, anyone have a diagram showing which connections are what, on the back of this head unit? PXL_20210130_224858614.jpg
