Banks Pedal Monster at Got Exhaust
Nick@GotExhaust
Preferred Vendor
SC
Improve throttle response, adjustable and safe
Bring your vehicle to life with PedalMonster. City, Sport, Track with 30 levels of control. The only OBD-II connected throttle sensitivity controller. Adjustable low-speed trim, reverse safety, and ActiveSafety circuitry included! PedalMonster stacks with any flash or inline tuner!!! Not just Banks.
PedalMonster is the first OBD-II connected throttle sensitivity controller for gas and diesel vehicles. Controlled via Banks iDash or mobile app, PedalMonster is the only module of its kind to offer safety features like ActiveSafety®, Reverse Safety and Adjustable Low-Speed Trim.
  • City, Sport, and Track modes, each with 10 sensitivity levels
  • OBD-II connected
  • ActiveSafety failsafe circuitry with Health Monitoring
  • Reverse safety returns pedal to stock in reverse gear
  • Adjustable Low-Speed Trim controls how fast sensitivity is added at slow speeds
  • Powered by +12V via OBD, not low-overhead pedal circuit
  • Controlled by iDash DataMonster, iDash SuperGauge and mobile app
  • PedalMonster stacks with any flash or inline tuner!!! Not just Banks
  • View PedalMonster's activity in real-time via iDash and mobile app
  • Simple plug-and-play installation
  • Warranty friendly. Does not leave footprint after removal.
Customize
City, Sport and Track, each with 10 levels of refinement, allows you to tune out "dead spots" found in many pedals, making your throttle more responsive. PedalMonster can be adjusted on-the-fly through the iDash and phone application. Simply take your foot off the pedal momentarily to adjust the mode or sensitivity level.
Control
PedalMonster is controlled via iDash DataMonster, iDash SuperGauge, and PedalMonster mobile app (iOS and Android). View PedalMonster's activity in real-time. When used with iDash, monitor vital engine and transmission OBD-II data, control PedalMonster, Derringer tuner, and other Banks modules.
OBD-II Connected
PedalMonster is the ONLY throttle sensitivity controller connected via the vehicle's OBD-II port (onboard diagnostics) reading vehicle data, allowing for unmatched control and safety. OBD-II data makes the following possible:
Safety
PedalMonster is the ONLY throttle sensitivity device with ActiveSafety®. In the event of an internal or external circuit failure, the system seamlessly returns the pedal to stock. When all other devices fail, they leave the vehicle inoperable leading to dangerous situations. Imagine losing power while passing on a two-lane road while heading into oncoming traffic.
All modern throttle pedals communicate with the vehicle's ECM via two distinct signals (APP1 and APP2). This is done for safety. PedalMonster's Health Monitoring constantly checks for signal linearity between these two signals and monitors input and output values. We monitor the health of PedalMonster 100 times a second. If the health monitoring system reveals any malfunction, the PedalMonster instantly bypasses itself, sets a device diagnostic code, and returns you to stock power.
PedalMonster's internal circuitry is powered by the reliable +12 volt OBD-II connector. Competitive devices draw current directly from the low-overhead +5 volt throttle pedal circuit, often rendering the vehicle inoperable leading to dangerous situations.
Reverse Safety
PedalMonster returns the vehicle to stock throttle response when in reverse gear (availability varies by vehicle).
This feature allows you to adjust the rate at which PedalMonster adds sensitivity at speeds under 10 mph. This helps to avoid spinning the tires in low speed turns or on slippery surfaces. While level 0 turns off low-speed trim, levels 2-5 increasingly minimize throttle boosting from 0-5 mph. By 10 mph PedalMonster will boost the throttle normally. This adjustment helps with low-speed drivability during parking lot maneuvering, icy roads, etc, while allowing you to use more an aggressive mode and level at the same time. For example, if you like Track mode but don't want to slip while driving slowly on icy roads, simply set the low-speed trim to Level 5.
You can also select transmission type: Automatic (default) or Manual. The Manual transmission setting does less boosting in the 0-20% pedal travel range (when compared to Automatic). This improves drivability during clutch engagement.
Contact us for pricing
Nick@GotExhaust
Nick@GotExhaust
Preferred Vendor
SC
message me for pricing
Nick@GotExhaust
Nick@GotExhaust
Preferred Vendor
SC
Between yesterday and this past weekend a ton of these shipped out. Lots of orders. these seem to be giving Pedal Commander a good run for the money. We offer and stock both of these options. Contact us for pricing
Nick@GotExhaust
Nick@GotExhaust
Preferred Vendor
SC
Nick@GotExhaust
Nick@GotExhaust
Preferred Vendor
SC
We just got some more back in stock for the 5th gens. Contact me for pricing before we sell out again!
Nick@GotExhaust
Nick@GotExhaust
Preferred Vendor
SC
IN stock, contact us for a quote
Allen C
Georgia
Nick
Can you provide the total cost for the Banks pedal monster for a 2021 Ram 1500?
Thanks
British Bulldog
Jacksonville NC
Hemi 5.7 etorque
Nick. Good day. Does this model Pedal Monster for 5th gen 2021 work with etorque?
No mention even on their web page
Thank you!
Nick@GotExhaust
Nick@GotExhaust
Preferred Vendor
SC
Thank you!
Hi, I am almost positive it does but I will reach out to Banks now to confirm.
Nick@GotExhaust
Nick@GotExhaust
Preferred Vendor
SC
Message us for pricing and availability.
WigSmeN
Ontario
Is this only for the eco diesel or does this work on a hemi. I’ve been in a Cummins for a long time trying to catch up a gas upgrades.
Thanks.
Nick@GotExhaust
Nick@GotExhaust
Preferred Vendor
SC
Thanks.
Works on ALL engines for the RAM. Message me if you would like a quote on one.
Nick@GotExhaust
Nick@GotExhaust
Preferred Vendor
SC
Contact us for pricing and info
Nick@GotExhaust
Nick@GotExhaust
Preferred Vendor
SC
message me for a quote and more info
Nick@GotExhaust
Nick@GotExhaust
Preferred Vendor
SC
safest throttle response controller on the market
Nick@GotExhaust
Nick@GotExhaust
Preferred Vendor
SC
Nick@GotExhaust
Nick@GotExhaust
Preferred Vendor
SC
Get rid of the lag in acceleration!
Nick@GotExhaust
Nick@GotExhaust
Preferred Vendor
SC
Best option on the market for throttle controller. Built in safety!
