Battery
michaelharris51
St. Louis
Hemi 6.1
Is there a way to check battery charge through the dash menus?
2021 1500 limited 5.7
Thanks
tron67j
Maryland
Your best bet is a load test, like a carbon pile load tester. A simple volt check may not give you a full picture, you could have good volts but low amps. If you're having a problem and your battery is a few years old, it's probably just best to go ahead and replace it anyways.
