Cam/Lifter job cost
Gladrich
New York
My 2013 hemi has the hemi tick. Pretty sure it’s a lifter. I’ve read a lot of threads about this issue and it sounds like the cam will also need to be replaced. I don’t have the tools or knowledge to perform this work myself. Does anyone have an idea of what this might cost at a garage? Also what can I expect if I keep driving it the way it is?
Thanks
Atcer2018
Virginia
Thanks
If you’re sure it’s lifters and not exhaust manifold bolts then you’ll want to get it repaired ASAP. If you catch the tick very early some people have reported saving the cam. Once the cam is scored it will need replacing. If you let it go the result will be needing a new engine. It will eventually not start or run. All the metal from the cam being ground down will make its way through the engine and not worth salvaging. Worst case the metal shavings clog the oil pump and the engine will starve for oil. Cost will depend on extent of damage. If caught early it’s cheaper as the cam may be saved and some people will elect to only have the offending lifter replaced instead of all of them. Will you have both banks replaced or just the offending side? Cost also depends on location. Having a shop do the repair you are looking at $5K or higher.
Gladrich
Gladrich
New York
Thanks allot for that. It has been driven about 8 miles with the tick. If I decide to fix it I’ll have it towed in. If the cam isn’t damaged I guess I should replace all the lifters.
sblack33741
Maryland
3.6L Pentastar ETorque
With all of that already removed, yes replace all of the lifters. Also, how much is a new engine? I would look as it may be cheaper.
BenWade
Houston
If it is the lifters and you caught it this early then I would suggest an aftermarket cam. There is nothing like a cammed hemi
Slinge
seattle
I would try Hemi Honey and 20 820 oil filter ?
Gladrich
Gladrich
New York
Turns out it is the exhaust. Broken bolts on the manifolds. My mechanic says he doesn’t do those jobs anymore. He is retiring soon so I need to find another. I have watched several you tubes on how to do it but I’m not confident that I can do it. Anyway thanks for the replies.
DeckArtist
Elmo, Tx
My neighbor had his exhaust bolts changed out on his 2017 a few months ago and the cost was around $550 or so at our local dealer.
Gladrich
Gladrich
New York
$550 seems doable. I’m wondering…I see all 5hese guys having hemi motor mount bolts breaking and all these guys having manifold bolts breaking…why isn’t there a class action lawsuit for these issues?
Nobody is breaking motor mount bolts on a Hemi,even the 1000+hp guys are using the stock mounts.That's one thing the trucks don't do,lol
