Condinsation caused by gasket seal where bulb goes in ?????
bcraig
I have a 2013 Ram 1500 Tradesman with the Quadlights and there is a LOT of condensation inside both the headlights.
I have read about the vents being pushed to far in or being clogged.
I am wondering if the gasket seal where the the bulb goes in and then the cover screws into the housing may be old and cracked and allowing moisture into the Housings ??
I will be replacing some bulbs in the near future and am thinking about replaceing the gaskets/seals just as a precaution against condensation along with checking the vents.
All that being said where can I find and buy the moisture seals ?????
Thanks
tron67j
Maryland
Should be able to get from Benny in our vendor section at All Mopar Parts, but could be complete socket (which wouldn't be the worst thing to do).
