Replacement bulb sea for Ram 1500 ?
bcraig
I have a 2013 Ram 1500 with Quad Headlights and have a lot of condensation in both headlights,I will be replacing some bulbs before too long and would like to know what the seal is called that is supposed to seal the screw on round door that is put back on the housing after replacing a bulb to seal the headlight from moisture ?
Will Just a rubber band or O ring seal it from moisture ?
Thanks
All
All
Thanks
The door and seal are not serviceable from Mopar but I would imagine a large o-ring is used. If you can measure it you should be able to find a suitable replacement online.
Please let me know if you have any other questions.
Thanks,
-Benny
