DIY: 2013-2018/Classic OEM Foglight Wiring (& some 09-12 info)
Mpgrimm2
Mpgrimm2
Preferred Vendor
SC
2022 Ram 1500 (5th Gen)
5.7L
Message sent
M² Mods.
(via Tapatalk App)
Mpgrimm2
Mpgrimm2
Preferred Vendor
SC
5.7L
Going to post this here for now until I can add it to the op properly....
A Cautionary Note about where 4th Gen owners buy your Foglight Bumper/Jumper harness from...
You SHOULD source the bumper/jumper harness from a MOPAR PARTS DEALER! Like Forum vendor @AllMoparParts !
** Please don't buy a cloned china version from Amazon or eBay if it's not from an authorized Mopar seller... The china version doesn't use quality bulb connectors or automotive grade wire **.
M² Mods.
(via Tapatalk App)
Sligo
Finally getting my color matched bumper next week. Will be installing everything next Wednesday. Just a quick question,when putting the pins into the connector ,there is no chance of the other pins falling out?
Mpgrimm2
Mpgrimm2
Preferred Vendor
SC
5.7L
Correct.
There a video linked in one of the first 5 posts that shows exactly what to do for installing the Foglight pins.
M² Mods.
(via Tapatalk App)
Sligo
Harness connected,truck already flashed. Hooked it up temporarily to check it. Both lights work. Thanks for the simple harness install. Have to admit. I was a little nervous pulling apart and putting in new connections to the plug. Was as simple as the video showed.
Mpgrimm2
Mpgrimm2
Preferred Vendor
SC
5.7L
It should
Sligo
If you're having the dealer do it? They should know the code. My dealer actually updated my vin # to include the fog lights if you pull it up.
Sking80
Atlanta Ga
Did you go to parts or service to get your vin updated with new sales codes
Mpgrimm2
Mpgrimm2
Preferred Vendor
SC
5.7L
You we'll have to have the service advisor add the code to your VIN so a tech can update/load it into the BCM. See the pdf directions linked a few posts up.
Sking80
Atlanta Ga
Thanks also pm me about harness please
