Gear Ratio
Magnum_59L
5.9L Magnum
New to the forum so I hope I can get some help. I have a 2001 Ram 1500 4x4 5.9L Magnum, has 5inch lift with 35s. I need help deciding what gear ratio I should upgrade or is it even worth doing? Anything will help.
DILLIGAF
Canada
35's is 4.56 or 4.88
I personally love 4.88s with the 35s on the JK
Magnum_59L
Magnum_59L
5.9L Magnum
Do you have a recommendation where i can get them?
TotallyHucked
Gainesville, Ga
2017 Sport CCLWB
If the truck is 4x4 would I have to replace the front gears as well?
Unless you want your transfer case to explode the first time you hit solid ground with 4x4 engaged, yes lol. The best thing for you to do would be to find a local 4 wheel drive shop, 4 Wheel Parts or similar. They can take care of you.
