Help
KillerBee2164
HEMI
ok i have a reg. cab 2004 dodge ram you all know well i hope you would or have saw how much room is behind the seats. i need some advice on what subs in a 12" would you put in a reg. cab dodge ram with amp that would pound the **** out of it????
if u can give me brand of sub with model # along with amp id appreciate it.
ramhunter9
P-Star Jeep Wrangler
in ol red ...my single cab , i built a custom box and put in 2 kenwoods they were 10's and ran a kicker 350.2 amp . sounded good
quietpeen
2021 TRX
Hellcat
are you talking obnoxious loud - hear the bass a couple blocks away pounding?
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
Depends on how you wanna run your truck. You will also have to think of air volume in your cab. 2 12s in a quad cab will hit diff in a 2 door even if the subs and amp are the same.
ramhunter9
10's or 8's for a single cab will sound better than 12's
you need air for 12's
quietpeen
2021 TRX
Hellcat
especially if he wants loud boomy bass because he will then want a ported enclosure with requires more cub. ft.
ramhunter9
also you will need to upgrade your high's unless you just want bass
