18CrewDually
- Nov 17, 2019
- 2,058
- 2,641
- Location
- U.S.- New Jersey
- 2018
- Cummins 6.7 H.O.
Ok. Bearing should be stamped STD for Standard size. Each set should be set in its rod, caps installed and torqued, then measured to check for proper clearence with the crank. This is done before install into the block. Sounds like you are a couple steps ahead without checking bearing clearence. Best of luck.thanks. i never pulled the engine. using the same pistons. think i got wrong sized bearings
